Aug 15th, 2024, 3:21pm
about static consumption (Read 3082 times)
endyson
Mar 10th, 2009, 4:02am
the definition of static consumption is the consumption excluding  switch activity.that means there may be two steady states for evaluating the static consumption, is it ?
looking forward to reply!
thank u!
raja.cedt
Re: about static consumption
Reply #1 - Mar 10th, 2009, 4:24am
i didn't get you what is mean by two steady states,but static power  consumption means  whenever there is  no switching activity that power is static power,in the contest of inverter only leakage power is static power consumption.
Rajasekhar.
endyson
Reply #2 - Mar 10th, 2009, 5:58am
oh, im sorry, I mean the two steady states high level and low level in digital circuits, for instance,  an inverter may have static consumption when input is high or low, and the static consumption may be different.
boe
Reply #3 - Mar 11th, 2009, 11:42am
Quote:
... the static consumption may be different.
Correct.
BOE
vivkr
Reply #4 - Mar 12th, 2009, 12:58am
endyson wrote on Mar 10th, 2009, 5:58am:
In that case, the number of states would be order 2^n for n independent digital paths Wink, not just 2.
Vivek
