Aug 15th, 2024, 5:29pm
Problem designing a CS amp (Read 888 times)
kidman
Mar 14th, 2009, 4:00pm
I am trying to design a CS amp and I'm using the gm/id methodology in my design. I am trying to achieve a gain of 50 with no BW specs or anything.The CS amp PMOS with a current sink load (NMOS). So the gain is gm(ro//ro). If the ro1=ro2 then the gain is gmro/2.
so what I do is try to get a gmro of 100 from the PMOS and then see the ro and try to achieve it in the NMOS too. But one of 2 things happens
1- Everything goes ok but when I connect both transistors to each other to form the amplifier the gain is changed
2-the NMOS either meets the specified current without meeting the r0 or vice versa.
Any idea what could be the reason for that?
AnalogDE
Re: Problem designing a CS amp
Reply #1 - Mar 15th, 2009, 1:15am
You're going to get discrepancies because in the gm/id method the plots are done assuming the transistor is in a diode-connected configuration (Vgs=Vds).  But in your CS amp this is not the case with either transistor.  Also, the gain will be sensitive to the input voltage and output voltage (it's not a static number).  You can't really set the gain precisely in an open loop configuration -- you need to have some sort of feedback.
Usually when you're designing an amp you design it so that it has a "high enough" gain (i.e. a minimum gain).  If you want precise gain then you need negative feedback.
