Jul 16th, 2024, 12:34pm
Pages: 1 2
ac gm simulation (Read 850 times)
vivarf
ac gm simulation
Mar 11th, 2009, 10:56pm
Hi all
In DC simulation, we can sweep the bias voltage (Vbias), and we can plot the dc I-V characteristics, and gm and gm'... over the large range of sweeping voltage (Vbias).
In "A 2GHz 16dBm IIP3 Low Noise Amplifier in 0.25μm CMOS Technology" paper the authors mentioned about AC characteristics, they can also plot the gm over input voltage range (it is AC Vinput, not Vbias).
Can anyone show me how to do this simulation to get that AC gm plot? Thank you very much.
You can check the paper out at this
http://ieeexplore.ieee.org/stamp/stamp.jsp?arnumber=01234383
View Profile veeater   IP Logged
Re: ac gm simulation
Reply #1 - Mar 13th, 2009, 8:16am
vivarf wrote on Mar 11th, 2009, 10:56pm:
Maybe this is a differential input transconductor. Is it correct ?
Apply swept DC values(-100mV ~ +100mV) as Vin_diff and then evaluate Y21 by executing AC analysis(2.5GHz) under each Vin_diff bias points.
g1 is calculated as g1=real(Y21).
g3 is calculated as g3=d2g1/dVin_diff2.
Although I don't see the following, I guess g1=g1+ + g1-. Is this correct ?
vivarf
Reply #2 - Mar 15th, 2009, 2:28am
Thank you pancho.
I may need to spend some time to carry the simulation as you suggested to confirm.
About the second figure, I also guess g1 = g1+ + (-) g1-,  not sure either  :(
vivarf
Reply #3 - Mar 17th, 2009, 4:45am
Hello pancho, sorry to bother you again
I carried the AC analysis.
At the result window of AC analysis, as shown below
I supposed Y21 = d[mag(Iout)]/dVin_diff
Is it??
Reply #4 - Mar 17th, 2009, 6:11am
vivarf wrote on Mar 17th, 2009, 4:45am:
No. You are completely misunderstanding.
Show me your netlist regarding
  signal sources statements
  analysis statements
  options statements
  save statements which you observe output currents.
I will correct your netlist.
And show me your definition of Y21 for differential output current.
I define it as Y21=(Iout+-Iout-)/(Vin+-Vin-).
Also I don't use Direct Plot of Cadence Spectre, since there exist many many unbelievable mistakes in definition.
I use Ocean Script where I write measurement by my own definition.
This is very common in Agilent Tool Environment.
vivarf
Reply #5 - Mar 17th, 2009, 7:08am
Hi pancho, thank you for your quick response !
Here my circuit, I just re-build the one that mentioned in the paper.
The option of the DC bias , one is Vbs2+vin, the other is Vbs2-vin
The option of the port (for AC analysis??)
Those resistors are all 0 just to check the current, and after AC analysis I just take out the current of 1 branch of the circuit at terminal of R (first Fig)
The ac analysis setting
Reply #6 - Mar 17th, 2009, 7:11am
 analysis statements
 options statements
Why do you use port ?
Anyway show me your netlist.
vivarf
Reply #7 - Mar 17th, 2009, 7:22am
The netlist:
// Generated for: spectre
// Generated on: Mar 17 22:37:31 2009
// Design library name:
// Design cell name:
// Design view name:
simulator lang=spectre
global 0
include "/cadence/IC5141/tools/dfII/samples/artist/ahdlLib/quantity.spectre"
parameters Vbs=.6 Rf_freq=455M Rf_freq2=450M Rf_pwr=-60 vin=0 Vbs2=500m \
   n1=18 n2=18 xxx=8
include "/tsmc13rf/../models/RF_12_33_FSG.scs"
subckt b_wire _1 _2
parameters length
   R0 (net5 _2) resistor r=0.2*length
   L0 (_1 net5) inductor l=0.8n*length
ends b_wire
// End of subcircuit definition.
// Library name:
// Cell name:
// View name: schematic
R28 (net088 net0276 ) rppolyhri l=15.0u w=1u m=1
R6 (net0150 net095 ) rppolyhri l=15.0u w=1u m=1
R2 (net067 net090 ) rppolyhri l=4.05u w=8u m=1
R31 (net069 net068 ) rppolyhri l=15.0u w=1u m=1
R27 (net0276 net093 ) rppolyhri l=15.0u w=1u m=1
R39 (net0162 net072 ) rppolyhri l=15.0u w=1u m=1
R38 (net072 net0274 ) rppolyhri l=15.0u w=1u m=1
R26 (net0274 net076 ) rppolyhri l=15.0u w=1u m=1
R35 (net068 net078 ) rppolyhri l=15.0u w=1u m=1
R36 (net076 net069 ) rppolyhri l=15.0u w=1u m=1
R34 (net078 o\- ) rppolyhri l=15.0u w=1u m=1
R30 (net092 net0275 ) rppolyhri l=15.0u w=1u m=1
R37 (net0275 net0162 ) rppolyhri l=15.0u w=1u m=1
R32 (net089 net088 ) rppolyhri l=15.0u w=1u m=1
R33 (o\+ net089 ) rppolyhri l=15.0u w=1u m=1
R29 (net093 net092 ) rppolyhri l=15.0u w=1u m=1
R45 (net095 net094 ) rppolyhri l=15.0u w=1u m=1
R21 (net097 net0150 ) rppolyhri l=15.0u w=1u m=1
R1 (net099 net0103 ) rppolyhri l=15.0u w=1u m=1
R44 (net0101 net097 ) rppolyhri l=15.0u w=1u m=1
R46 (net0103 net090 ) rppolyhri l=15.0u w=1u m=1
R40 (net066 net0101 ) rppolyhri l=15.0u w=1u m=1
R0 (net0107 net099 ) rppolyhri l=15.0u w=1u m=1
R5 (net094 net0107 ) rppolyhri l=15.0u w=1u m=1
M20 (cmfb cmfb net066 net066) pmos_rf lr=130.0n wr=2u nr=8 m=1
M13 (bias1 net0116 net066 net066) pmos_rf lr=350.0n wr=2u nr=2 m=1
M9 (o\- cmfb net066 net066) pmos_rf lr=130.0n wr=4u nr=64 m=2
M50 (o\+ cmfb net066 net066) pmos_rf lr=130.0n wr=4u nr=64 m=2
M21 (net0160 net0160 net066 net066) pmos_rf lr=130.0n wr=2u nr=8 m=1
M14 (net0116 net0116 net066 net066) pmos_rf lr=350.0n wr=2u nr=2 m=1
I298 (0 net090) b_wire length=2
I296 (0 net062) b_wire length=2
K0 (net0112 0 net215 net025) transformer
C2 (net025 in\-) capacitor c=10p
C1 (net215 in\+) capacitor c=10p
M11 (net0116 bias1 net067 net067) nmos_rf lr=350.0n wr=2u nr=1 m=1
M19 (cmfb net0150 net0156 net0156) nmos_rf lr=130.0n wr=2u nr=4 m=1
M16 (net0156 bias1 net090 net090) nmos_rf lr=350.0n wr=2u nr=4 m=1
M17 (net0156 bias1 net090 net090) nmos_rf lr=350.0n wr=2u nr=4 m=1
M18 (net0160 net0162 net0156 net0156) nmos_rf lr=130.0n wr=2u nr=4 m=1
M15 (net0116 net0116 bias1 bias1) nmos_rf lr=130.0n wr=2u nr=16 m=1
M12 (bias1 bias1 net090 net090) nmos_rf lr=350.0n wr=2u nr=1 m=1
M64 (net018 in\- net043 net043) nmos_rf lr=130.0n wr=2u nr=xxx m=1
M6 (o\- net0132 net074 net074) nmos_rf lr=130.0n wr=2u nr=n1+n2 m=1
M68 (net043 in\+ net062 net062) nmos_rf lr=130.0n wr=2u nr=n2 m=1
M5 (net036 in\- net062 net062) nmos_rf lr=130.0n wr=4u nr=n1 m=1
M3 (net044 in\+ net040 net040) nmos_rf lr=130.0n wr=2u nr=xxx m=1
M4 (net040 in\- net062 net062) nmos_rf lr=130.0n wr=2u nr=n2 m=1
M0 (net014 in\+ net062 net062) nmos_rf lr=130.0n wr=4u nr=n1 m=1
M2 (o\+ net021 net084 net084) nmos_rf lr=130.0n wr=2u nr=n1+n2 m=1
R17 (net0132 net064) resistor r=10K
R7 (net014 net048) resistor r=0
R14 (in\- net070) resistor r=10K
R15 (net044 net096) resistor r=0
R12 (net036 net096) resistor r=0
R19 (net096 net074) resistor r=0
R3 (in\+ net042) resistor r=10K
R4 (net018 net048) resistor r=0
R18 (net048 net084) resistor r=0
R10 (net021 net050) resistor r=10K
V39 (net066 0) vsource dc=1.2 type=dc
V37 (net070 0) vsource dc=Vbs2-vin type=dc
V38 (net064 0) vsource dc=1 type=dc
V26 (net042 0) vsource dc=Vbs2+vin type=dc
V35 (net050 0) vsource dc=1 type=dc
PORT0 (net0112 0) port r=50 num=1 type=sine freq=Rf_freq dbm=Rf_pwr \
       freq2=Rf_freq2 dbm2=Rf_pwr mag=100m fundname="Rf1" fundname2="Rf2"
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27.0 \
   checklimitdest=psf
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
dc dc param=vin start=-450m stop=2 lin=200 oppoint=rawfile maxiters=150 \
ac ac freq=400M param=vin start=-100m stop=100m lin=200 annotate=status
tran tran stop=50n step=10p maxstep=40p write="spectre.ic" \
   writefinal="spectre.fc" annotate=status maxiters=5
finalTimeOP info what=oppoint where=rawfile
saveOptions options save=all pwr=all currents=all useprobes=yes \
   saveahdlvars=all
I just check single branch output, because in the paper, I think they use single-ended. And the expression of Y21:
Y21=deriv(i("/R18/MINUS" ?result "ac"))
« Last Edit: Mar 17th, 2009, 8:56am by vivarf »
Reply #8 - Mar 17th, 2009, 8:36am
I don't need full netlist.
Read my requests surely.
You should not use Resistor of 0ohm for observing current.
Instead use vsource of dc=0Volt or iprobe.
Your netlist is too dirty and wrong, so it is laborious to correct.
vivarf wrote on Mar 17th, 2009, 7:22am:
Delete these lines completely. And replace to the followings.
V26 (in\+ 0) vsource type=dc dc=Vbs2+vin/2 mag=0.5 phase=0
V37 (in\- 0) vsource type=dc dc=Vbs2-vin/2 mag=0.5 phase=180
Modify this line to the following.
ac ac freq=400M param=vin start=-100m stop=100m lin=200 annotate=status restart=yes
You are misunderstanding completely.
Y21=i("/M2/D" ?result "ac")-i("/M6/D" ?result "ac")
g1=real(Y21), g3=deriv( deriv(g1) )
If you prefer single-ended output, Y21=i("/M2/D" ?result "ac").
I can't find out output terminals for g1+ and g1- correctly.
If you specify output terminals correctly for them, you can calculate g1+ and g1- by same definition as g1.
I've been very tired due to your unbelievable misunderstanding netlist.
« Last Edit: Mar 17th, 2009, 9:58am by pancho_hideboo »
vivarf
Reply #9 - Mar 17th, 2009, 8:54am
My mistake, because I hardly use the script, so netlist is not familiar with me
Pancho, thank you very much, I really appreciate.
« Last Edit: Mar 17th, 2009, 6:29pm by vivarf »
Reply #10 - Mar 17th, 2009, 9:36am
In Spectre there is nothing wrong with using a zero ohm resistor to measure current, just like it is fine to use a zero volt voltage source. Using the iprobe is actually preferred because it is a very simple and light weight component.
Reply #11 - Mar 17th, 2009, 9:55am
Ken Kundert wrote on Mar 17th, 2009, 9:36am:
I feel it comes to be slow if I use resistor of 0ohm instead of vsource of 0Volt when I run HB analysis of Cadence Spectre.
Reply #12 - Mar 17th, 2009, 7:17pm
vivarf wrote on Mar 17th, 2009, 8:54am:
Can you understand what is your misunderstanding ?
wave
Reply #13 - Mar 17th, 2009, 7:36pm
Ken - When I use tiny R's, I find abstol, reltol type of issues.
Usually atleast 100 mOhms is a good compromise.
Vdc=0 works well for me, as it back annotates well.
I've never understood why iprobe exists.
Doesn't back annotate that well.
Oddly, the STB analysis can use either device, and I'm curious if there is a tradeoff.
Usually I swap out my STB symbol for Metal R's, so it's always good to have a value that converges Cool
~Wave
vivarf
Reply #14 - Mar 17th, 2009, 8:36pm
I am still a little confused here
The original definition: Y21=Id/Vin
The result you defined is taken out current: Y21=i("/M2/D" ?result "ac")   (single-ended)
From the original definition, I thought Y21 = deriv(i("/M2/D" ?result "ac"))
Pages: 1 2
