Jul 2nd, 2025, 6:11am
Verilog-A model for a sinusoidal voltage source with jitter (Read 1424 times)
zoujunjx
Mar 13th, 2009, 3:15am
I need a behavioral model in Verilog-A for a sinusoidal voltage source with input random jitter. Anyone can help me? Many thanks in advance!  :)
Re: Verilog-A model for a sinusoidal voltage source with jitter
Reply #1 - Mar 13th, 2009, 9:04am
zoujunjx wrote on Mar 13th, 2009, 3:15am:
See http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf
zoujunjx
Reply #2 - Mar 17th, 2009, 2:28am
Thanks a lot! However, I need a sinusoidal voltage source with input random jitter, while the model in your mentioned paper is only square waveform.
Reply #3 - Mar 17th, 2009, 6:22am
zoujunjx wrote on Mar 17th, 2009, 2:28am:
Compared to square waveform, sinusoidal waveform is very easy.
Did you read surely with considering possiblity of extension or application.
Use Phase Modulation sources modulated by random signal.
Reply #4 - Mar 17th, 2009, 9:28am
The Verilog-AMS page has vco models that are simple to convert to sinusoidal output. Perhaps you can use them. For example, the model of the vco with jitter is
// Voltage controlled oscillator with white accumulating jitter
module vco2 (out, in);
input in; voltage in;				// input terminal
output out; voltage out;			// output terminal
parameter real vmin=0;				// input voltage that corresponds to minimum output frequency
parameter real vmax=vmin+1 from (vmin:inf);	// input voltage that corresponds to maximum output frequency
parameter real fmin=1 from (0:inf);		// minimum output frequency
parameter real fmax=2*fmin from (fmin:inf);	// maximum output frequency
parameter real vl=-1;				// high output voltage
parameter real vh=1;				// low output voltage
parameter real tt=0.01/fmax from (0:inf);	// output transition time
parameter real ttol=1u/fmax from (0:1/fmax);	// time tolerance
parameter real jitter=0 from [0:0.25/fmax);	// period jitter (produces white accumulating jitter)
real freq, phase, dT;
integer n, seed;
analog begin
    @(initial_step) seed = -561;
    // compute the freq from the input voltage
    freq = (V(in) - vmin)*(fmax - fmin) / (vmax - vmin) + fmin;
    // bound the frequency (this is optional)
    if (freq > fmax) freq = fmax;
    if (freq < fmin) freq = fmin;
    // add the phase noise
    freq = freq/(1 + dT*freq);
    // bound the time step to assure no cycles are skipped
    $bound_step(0.6/freq);
    // phase is the integral of the freq modulo 2p
    phase = 2*`M_PI*idtmod(freq, 0.0, 1.0, -0.5);
    // update jitter twice per period
    // `M_SQRT2=sqrt(K), K=2 jitter updates/period
    @(cross(phase + `M_PI/2, +1, ttol) or cross(phase - `M_PI/2, +1, ttol)) begin
	dT = `M_SQRT2*jitter*$rdist_normal(seed,0, 1);
	n = (phase >= -`M_PI/2) && (phase < `M_PI/2);
    // generate the output
    V(out) <+ transition(n ? vh : vl, 0, tt);
To convert it to sinusoidal output, change the lines Code:
to Code:
    V(out) <+ sin(phase);
nadroit
Reply #5 - May 31st, 2012, 9:12am
Hello Ken,
 I do not understand why value of K is changed from 2 to 1 for the jitter in sine wave oscillator. For square wave jitter is updated twice per period but for sine wave it is updated once per period why?
Forum Administrator
YaBB Administrator
Reply #6 - May 31st, 2012, 9:53am
When generating a square wave it is natural and convenient to do it twice per cycle, but it is not necessary to do it so often. Once is sufficient.
Reply #7 - Jan 30th, 2013, 1:44pm
Hi Ken,
Why is the bound step 0.6/freq? Is it too big?
Yawei
