Apr 29th, 2024, 3:46pm
In Composer, pass down parameters for veriloga block (Read 2673 times)
neoflash
Mixed-Signal
Designer
Apr 02nd, 2009, 12:06pm
Need help to pass down the parameters in cadence composer, for veriloga blocks.
Thanks.
Re: In Composer, pass down parameters for veriloga block
Reply #1 - Apr 4th, 2009, 2:45pm
If you just specify the parameters in your Verilog-A code, when you exit the editor (after saving), it should automatically define these parameters in the CDF. When you instantiate the block, you'll probably need to use the "Use Tool Filter" cyclic field on the edit properties form, and then you should be able to see any of the parameters you defined in the VerilogA code - and you can set them on the instance.
