Jul 6th, 2025, 4:58pm
Bandpass sampling (Read 955 times)
Mahyar
Bandpass sampling
Apr 02nd, 2009, 1:59pm
Hi guys,
For my master thesis I need to model and design a uniform quadrature bandpass sampling (UQBS) circuit. Do you have any good reference. specially for modeling the system in MATLAB and implementation.
regards,
M
Re: Bandpass sampling
Reply #1 - Apr 11th, 2009, 3:50am
Mahyar wrote on Apr 2nd, 2009, 1:59pm:
What is UQBS ?
What is different from conventional qudrature bandpass sampling ?
Uniform sampling is common although theoretically non-uniform sampling is possible.
Your sampling is nyquist-sampling(over sampling) or under-sampling of bandpass signal ?
Mahyar
Reply #2 - Apr 11th, 2009, 5:03am
UQBPS is the uniform quadrature bandpass sampling which is the same as conventional quadrature bandpass sampling but since it is uniform it is easier to be realized as the implementation point of view. For sure it is an under sampling system since it wants to be a solution for software defined radio and the aim is to relax the requirements on ADC e.g high sampling rate.
At the moment I have two basic questions to ask:
1- How to express and show a single sideband bandpass signal in MATLAB.
2- I have the transfer function of a complex FIR filter and the coefficients but I don't know how to express it in MATLAB and see its response to my single sideband signal.
Mahyar
Reply #3 - Apr 11th, 2009, 5:21am
MATLAB are different from Simulink.
Do you intend to mean MATLAB not Simulink ?
The followings are general notes.
 - Use correct terminologies.
     - Warnigns are different from Errors.
     - ADS is not name of simulator.
     - There is no tool which name is Cadence.
     - All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
     - MATLAB are different from Simulink.
 - Learn measurements using actual instruments. Not "EDA Tool Play".
Mahyar wrote on Apr 11th, 2009, 5:03am:
Which of model in the followings do you use ?
(1)Real RF Signal, (I(t)+j*Q(t))*exp(j*omega0*t)
(2)Equivalent Lowpass Representation of RF Signal, {I(t)+j*Q(t), omega0}
http://www.designers-guide.org/Forum/YaBB.pl?num=1233929450/1#1
In your case, you have to use (1).
Attached figure is a conventional quadrature bandpass signal sampling using a single sampler.
Here you can't get I and Q at same time. Time difference of Ts always exists.
See the followings.
http://en.wikipedia.org/wiki/Digital_down_converter
page.14-16 of http://cp.literature.agilent.com/litweb/pdf/5989-9003EN.pdf
http://www.mathworks.com/applications/dsp_comm/demos.html?file=/products/demos/s...
http://www.altera.com/support/examples/dsp-builder/exm-digital-down-conv-cic-fir...
Which do you use single or dual sampler ?
What effects do you want to focus on in modeling quadrature sampler using Simulink ?
Multiple folding noise ?
Effect of Sampling Jitter in under-sampling system ?
If you only have interest on complex FIR, you don't have to model quadrature sampling at all.
Just create analytic signal representation of real signal.
Also see http://www.designers-guide.org/Forum/YaBB.pl?num=1207225157
« Last Edit: Apr 12th, 2009, 5:02am by pancho_hideboo »
