Oct 3rd, 2026, 3:56am
Generating a digital sine-wave (Read 3714 times)
mowiehowie
Apr 04th, 2009, 2:20am
Hello
I am testing a DAC design on Cadence and until now the digital inputs are given by a vector file.
I wanna test the THD, so I need to generate a digital sine-wave.
How could it be done?
Thank you.
Re: Generating a digital sine-wave
Reply #1 - Apr 4th, 2009, 6:09am
Put a sine-wave voltage source in the schematic, and quantize the sine wave using an ideal ADC, say ADC in ahdlLib.
Yawei
Mahavir
India
Reply #2 - Apr 4th, 2009, 1:19pm
I am also working on similar stuff.
You can write a verilog code of memory that stores say 100 samples (memory size will be 100 X 8) of sine wave ( you can use matlab ) and import it in spectre as module.
Hope, this will be useful.
View Profile WWW Mahavir   IP Logged
Reply #3 - Apr 5th, 2009, 4:15pm
And if you are pressed for memory, do the numbers for one quarter of the sine wave, and handle the sequencing of the output to reconstruct the whole waveform (pointer counts up 1/4 cycle, down 1/4 cycle, up 1/4 cycle with polarity reversal, down 1/4 cycle with polarity reversal)
You get the idea.
