Aug 14th, 2024, 3:00pm
Noise simulation in 0.13um CMOS (BSIM3v3) (Read 2925 times)
Berti
Apr 06th, 2009, 5:32am
I have simulated (with both noise and pnoise analysis) a basic sample and hold circuit (see attachment) in a 0.13um CMOS technology. If I use the available Spice2 model I basically obtain the same results I get from hand calculations (kT/C). However, if I use the BSIM3v3 model the simulated noise is 40-60% lower.
Is there a physical explanation or can I simply not trust the BSIM model?
vivkr
Re: Noise simulation in 0.13um CMOS (BSIM3v3)
Reply #1 - Apr 6th, 2009, 11:42pm
Hi Berti,
Assuming that you have not missed out anything in the calculation, I would say that you cannot trust the model you have been given by your foundry. The BSIM3 model in itself should be OK. I have used it quite many times and it passes this basic check although the noise I get is not exactly kT/C but a few % more in most cases.
This is the unfortunate problem with models of higher and higher complexity which sacrifice physical common sense in order to model everything, and then someone forgets to characterize something correctly and puts in some number.
I would use the SPICE2 model in this case. You obviously know how to switch it with the noimod parameter.
Best regards,
Vivek
