Aug 14th, 2024, 3:00pm
BSIM4 model Parameter llpe0 (Read 6540 times)
cmos.analogvala
India
Apr 05th, 2009, 4:28am
I have four corner moel file given by foundry for 90nm technology.  This model file has BSIM4 models of MOSFETs. There is a parameter llpe0 in this model file. I want to know what is the physical significance of this parameter ? This parameter indeed affects dc response of a MOSFET. I could not find any parameter like llpe0 in BSIM4 manual .
Does anybody know what is physical significance of llpe0 ?
Re: BSIM4 model Parameter llpe0
Reply #1 - Apr 6th, 2009, 2:10am
If using spectre, you can use "spectre -h bsim4" and then you'll see:
Quote:
536     llpe0=0.0         Length dependence of lpe0.
And also:
Quote:
73      lpe0=1.74e-7 m    Lateral non-uniform doping at Vbs=0.
I think you should find lpe0 in the bsim4 documentation though?
cmos.analogvala
India
Reply #2 - Apr 9th, 2009, 2:50am
Yes lpe0 is there in BSIM4 model. If I want to perform montecarlo simulations and don't have foundary specific model file, should I vary llpe0 and lpe0 both ?
Reply #3 - Apr 14th, 2009, 4:56am
No, don't vary llpe0.  llpe0 is a hack that, when used properly, can help connect lmin/lmax bins such that the final lpe0 value is continuous across bin boundaries.
However, I also don't think that most people vary lpe0, either -- only things like TOX, VFB, DL, DW.
cmos.analogvala
India
Reply #4 - Apr 23rd, 2009, 8:06am
Thanks for the reply,
I have also seen people varying only tox, VFB, dL and dW only.  However lpe0 being halo doping coefficient. Shouldn't  we vary lpe0 for Montecarlo simulations ? Montecarlo simulation files supplied by foundary include variation in which all parameters ?
CA
Reply #5 - Apr 28th, 2009, 4:58am
I think that VFB is an "average" flatband voltage, which includes the effect of pocket implant.  I would expect lpe0 variation to be a second-order effect (how much does the channel doping differ from the pocket).
Probably most foundries use the basic four; I think I've heard of some that used VTH instead of VFB, but maybe there's a paper saying why this is wrong (correlation of TOX and VTH).  Certainly, you could set up a MC sim varying each and every parameter in the BSIM4 model set, but you'd have to run lots more sims and accept the memory penalty (each device has a different value of *each* parameter).
