Aug 19th, 2024, 7:16am
how 2 reduce the systematic offset of a folded cascod comparator (Read 3411 times)
Tofu
Apr 07th, 2009, 4:09pm
Hi:
I made a comparator based on folded cascode structure due to headroom issue. It's systematic offset is in the range of 3mv which is a bit large than the spec (<900uv). I wonder if there is any knobs (e.g., current, diff pair, load, etc) for this type of architecture that I can tune to decrease the number?  and how?
thanks a lot!
wave
Re: how 2 reduce the systematic offset of a folded cascod comparator
Reply #1 - Apr 7th, 2009, 5:52pm
Sounds like your folded legs may not match.  Check their currents, Vds, and Early effects.
Grin
Wave
raja.cedt
Reply #2 - Apr 8th, 2009, 12:49am
have you got expected output common mode voltage?and check common mode at two outputs,if they are not symmetric..as he said its like current mismatch problem,.And  if possible decrease the overdrive voltage of differential pair..it may help
rajasekhar.
Reply #3 - Apr 17th, 2009, 10:50pm
Offset is almost always dominated by the mismatch of the differential pair at the input.
You should consider an architecture that has minimal systematic offsets and then uses a method of offset cancellation to deal with mismatch issues.
