raja.cedt
hi, i think the impedance's what you have shown in the slides are at the dc,but as soon as you cross dominant pole output load cap will start dominant and impedances at other nodes are 1/gm, so pole's are at gm/cp.This assumption holds good if cl/cp is very high, otherwise above approximation won't work ..
Thanks, Rajasekhar.
