Aug 18th, 2024, 7:28pm
Load current of bandgap voltage reference (Read 5524 times)
misc
Apr 08th, 2009, 3:45am
Dear all,
  i am designing a current summing voltage refreence for and ADC . My requirement is 1.4Volt output with 50uA load curent. But when i tried simulation for load regulation using the 50ua load current my Vref is oscillationg very badly. Please some suggest me how to improve the load current variation for my requirement.
Thankx in dvance
raags
Berti
Re: Load current of bandgap voltage reference
Reply #1 - Apr 8th, 2009, 4:24am
If you really expect a useful answer you should post a schematic.
Cheers
misc
Reply #2 - Apr 8th, 2009, 5:56am
 i  have atatched the schematic for your reference.
thanks in advance
raags
Berti
Reply #3 - Apr 8th, 2009, 7:52am
What kind of ADC do you use?
A bandgap is generally not well suited to drive loads. It is therefore not surprising that you have problems. You should add an additional buffer.
Cheers
PaloAlto
Reply #4 - Apr 8th, 2009, 8:40am
Sorry, I didn't understand it at first  :D Now, I see your point, you are trying to draw 50uA from the bandgap voltage node. No, you shouldn't do that. Think about it, as Berti says, if you try to get 50uA from that node you are subtracting it from the current that should flow into the resistor to generate the voltage level. So you are changing it. What tou should do is add some kind of buffer. Even a very small one, since 50uA is almost nothing
misc
Reply #5 - Apr 8th, 2009, 8:05pm
Dear berti and paloAtto,
  thank you for the information. To be clear i am using this bandgap for SAR ADC reference voltage generation. . We are trying to improve the accuracy of ADC by implementing onchip BGR along with SAR ADC. We thought of using a buffer at the output of BGR, but we are worried about the power consumption. We are having a very stringent power budget including BGR and ADC of about 300u. already my BGR is consuming a power of 80u and and i am really worried about power if i use another buffer in between. So any inputs on addressig these issues would be of great help.
TIA
raags
solidstate
Munich, Germany
Reply #6 - Apr 9th, 2009, 1:56am
80uA ( or uW?) seems like a lot for a bandgap reference.. what determines the need for that current?
misc
Reply #7 - Apr 9th, 2009, 2:53am
Dear solidstate,
   Since i am using an opamp based Bandgap reference the current drawn is 80uA as of now. Any info on imprving load regulation of Bandgap reference without an additional buffer amplifier would be appreciated.
TIA
raags
Berti
Reply #8 - Apr 9th, 2009, 3:26am
Raags,
I think you take the wrong approach. You should try to reduce the power consumption of your bandgap and spend that for a buffer.
I don't think that using the bandgap to drive the reference of a SAR will result in a power efficient solution.
Cheers
misc
Reply #9 - Apr 9th, 2009, 3:38am
dear berti,
 i am using a resistor network to generate the different voltages required for SAR ADC which will vary with VDD variations. I want to reduce this variations using a bandgap voltage reference. If i am using a buffer with bandgap reference the output of buffer is coupled with VDD variations again and i might loose the accuracy. So am i looking for a voltage refence for my ADC to improve the accuracy. any info on this is higly appreciated.
TIA
raags
Tlaloc
Dallas, TX
Reply #10 - Apr 14th, 2009, 12:39pm
I agree with Berti.  You should be able to greatly reduce the current consumption in the bandgap and use the leftover for a buffer.  I don't understand your concern about using a buffer though.  You will have the PSRR modify the output of the buffer, but it is still very strongly coupled to the bandgap voltage, not the supply voltage.  In short, when your Vbg is generated from a current, that leg can have no load current, or you will have large errors.
Also, why did you choose this architecture?  Have you looked at the variation of the output due to offsets of the amplifier?  It can vary by quite a bit.  There may be other architectures that would better fit your requirements.
