PaloAlto
Sorry, I didn't understand it at first :D Now, I see your point, you are trying to draw 50uA from the bandgap voltage node. No, you shouldn't do that. Think about it, as Berti says, if you try to get 50uA from that node you are subtracting it from the current that should flow into the resistor to generate the voltage level. So you are changing it. What tou should do is add some kind of buffer. Even a very small one, since 50uA is almost nothing
