Jul 2nd, 2025, 9:16pm
DAC's phase noise (Read 8962 times)
maxiao0116
DAC's phase noise
Apr 08th, 2009, 8:39am
i want to simulate the phase noise of a 14bit Didigtal to Analog Converter .
but i am not sure if my pss and pnoise configurations are right
i use a digital module to generate a 80MHz sinewave data and pass it to the DAC, DAC and digital module are
both using 400MHz sampling frequency. The final differential outputs from DAC is a 14bits 80MHz square wave.
i set the pss fundamental freq to 400MHz and beat freq to 80MHz,  15 harnomics. The PSS converged after 11 iterations.
my question is
1. are those configurations right? i got a pnoise plot from 100Hz@-130dBc/Hz downto 10MHz@-140dBc/Hz, almost flat!
2. what can i do if i want to simulate a 160MHz output frequency which doesn't have integer multiples with 400MHz sampling frequency
3. what type of noise i should use in Pnoise Analysis, source?jitter?, i used source.
4. if i combine the digital module and DAC together (sampling clock is generated from digital module in verilog), it seems like an oscillator,
Can i use the "Noise aware PLL flow" to  convert the whole circuit to PPV based behaviour module ?
thanks
Re: DAC's phase noise
Reply #1 - Apr 10th, 2009, 7:59pm
maxiao0116 wrote on Apr 8th, 2009, 8:39am:
No. You are wrong. Fundamental frequency is 80MHz in your case.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1232036048/4#4
I think your settings must be wrong for both PSS and Pnoise.
How do you set "sweeptype" in Pnoise ?
You should set like followings.
 aho  pss  fund=80M  harms=0  maxacfreq=4G errpreset=moderate annotate=status  outputtype=time
 boke pnoise start=10 stop=100M dec=11 maxsideband=50
 + sweeptype=relative relharmnum=1 annotate=status
You don't seem to understand PSS analysis.
There is no problem if you set 80MHz as Fundamental frequency in PSS.
160MHz=2*80MHz, 400MHz=5*80MHz.
In this case you have to set relharmnum=2.
It is dependent on your interest.
I have no answer for this since I'm not Cadence Tool's Player.
Some Cadence guys in this forum, e.g. sheldon, Andrew Beckett, Tawna Wilsey might answer for this.
« Last Edit: Apr 11th, 2009, 2:22am by pancho_hideboo »
Reply #2 - Apr 12th, 2009, 8:27am
I don't really see why you think it's like an oscillator? It's not autonomous, is it? Or perhaps I've misunderstood your circuit...
Reply #3 - Apr 12th, 2009, 9:15am
Max,
  Some additional comments,
1) Why is the output a square wave? As Panchoo Hideboo commented
   the choice of frequencies is probably not appropriate. Attached is
   an example using the results for PSS analysis of a DAC using the
   setup described in previous appends related to ADC test setup.
   Note: The DAC output should be a sine wave if the input is a
            sine wave. In this case, the time domain waveform is not
            shown, however, it was a sine wave as can be seen by the
            output spectrum.
2) The circuit is driven, using autonomous analysis is not is not
   appropriate.
3) The Noise-Aware PLL flow supports PLL simulation and is not
    appropriate for this case.
maxiao0116
Reply #4 - Apr 12th, 2009, 10:59pm
Thank you very much pancho hideboo. i think i misunderstood "beat freq" and "funda freq".
i should use such fundamental frequency whose multiples can represent all the frequency components in real spectrum, is that right?
if i want to get PSS solution for a 160MHz outputs, i should use 80MHz whose 2nd harnomics is the actual signal, and 5th harnomics is clocking feedthrough.
To Andrew Beckett:
 My system is a Direct Digital Synthesizer, it tunes the output frequency by just modifing the digital "Frquency Ctrol Word", like F = Kvco*V in digital, expect a constant sampling frequency should be provide in addition.
 if i encapsulate the digital part, DAC and sampling frequency source, i can pin to pin match a typical VCO symbol, and also the general functions.
 i am wondering if it's work because it's very time consuming to simulate the DDS's narrow band spurs.
To sheldon:
     i think i made a misunderstanding, the "square wave" i mentioned is acutally "sine weighted square wave". I say it square because the output is not filtered by LPF yet. I got a similar SFDR plot like you.
     I know it's not an autonomous system, but can i force it to use perturbation vector if i encapsulate the whole system to a pin2pin matched vco in Noise-Aware PLL flow and finish all the required simulations in that flow?
Thank you all.
