Apr 26th, 2024, 6:31pm
How to simulate mixer and LO together for measuring mixer IP3? (Read 2758 times)
samiraaa
Apr 11th, 2009, 5:54pm
Hi all
how can I measure mixer's IP3 when I have the LO in my circuit. so large signal input for mixer is not an ideal sine wave with desired frequency, it is the output of VCO.  That will be great if one tells me how I should set the QPss and PAC simulations in spectra.
Thank you
Re: How to simulate mixer and LO together for measuring mixer IP3?
Reply #1 - Apr 11th, 2009, 10:26pm
samiraaa wrote on Apr 11th, 2009, 5:54pm:
You mean Cadence Spectre not Spectra ?
If so, PAC is not slave analysis for QPSS.
Master analysis of PAC is PSS. Slave analysis of QPSS is QPAC not PAC.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1227668750
You can do simulation without using autonomous QPSS although it is a simple evaluation and lacking in accuracy.
Capture one-period waveform VCO alone or VCO with Mixer as Load using PSS.
Use "analogLib/vpwlf" or "analogLib/ppwlf" with frequency scaling in QPSS analysis for IP3 evaluation.
Here you can do IP3 evaluation using conventional two-tones-QPSS with QPAC.
RF1 and LO are treated as large signal in QPSS.
RF2 is treated as small signal in QPAC.
Also see http://www.designers-guide.org/Forum/YaBB.pl?num=1238150066
The followings are general notes.
  - Use correct terminologies.
      - Warnigns are different from Errors.
      - ADS is not name of simulator.
      - There is no tool which name is Cadence.
      - All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
      - MATLAB are different from Simulink.
  - Learn measurements using actual instruments. Not "EDA Tool Play".
« Last Edit: Apr 12th, 2009, 2:09am by pancho_hideboo »
