Aug 19th, 2024, 11:21am
[ECE264][Q1] Regarding the parasitic pole location in the Triple-Cascode Opamp? (Read 150 times)
NiceFeng
Apr 12th, 2009, 12:46am
Dear All,
 I am studying the lecture notes of ECE264 from USD by Prof.Song.
 In the slide talking about the Triple-Cascode Opamp (TCO), it is interesting to find the impedance of each node is pretty high, ½ro(gmro)2 for the output node, and ½ro(gmro) for the node where parasitical pole locates.
 I am a little bit confusing that the parasitical pole location should be around 1/(½ro(gmro) Cp). But it is indicated in the slide the pole is locating at gm/Cp.
 Could anyone explain it to me?
 Thanks a lot!
Feng
nobody
Re: [ECE264][Q1] Regarding the parasitic pole location in the Triple-Cascode Opamp?
Reply #1 - Apr 13th, 2009, 2:03am
Rp|LF=½ro(gmro), Rp|HF=1/gm
Therefore, the pole is located @ gm/Cp.
raja.cedt
Reply #2 - Apr 13th, 2009, 6:02am
hi,
   i think the impedance's what you have shown in the slides are at the dc,but as soon as you cross dominant pole output load cap will start dominant and impedances at other nodes  are 1/gm, so pole's  are at gm/cp.This assumption holds good if cl/cp is very high, otherwise above approximation won't work ..
Rajasekhar.
NiceFeng
Reply #3 - Apr 18th, 2009, 9:42am
Hi,Rajasekhar,
  Thanks for your explanations.
  This question reflects one of my misunderstanding points on pole/zero estimation. I always estimated that based on the DC impedance, which is not always true. Actually the second pole in this op-amp is frequency dependant.
Feng
