Aug 18th, 2024, 3:19pm
transient load for bandgap voltage reference (Read 1826 times)
misc
Apr 13th, 2009, 8:38pm
Dear forumites,
  i am designing a bandagap voltage reference for and ADC. When i check for load current simulation for my architecture i found the bandgap voltage switching between certain voltages. i am expecting this to be constant with load current variations. I have attached transient load current response for reference, any inputs how to make my output constant with load current varions is of great help.
TIA
Raags
misc
Re: transient load for bandgap voltage reference
Reply #1 - Apr 13th, 2009, 8:40pm
also i am attaching the block level schematic for the reference
thanks in dvance
raags
raja.cedt
Reply #2 - Apr 14th, 2009, 2:47am
hi Raags,
              you should not draw current from the band gap,if you want draw put a buffer and then connect load,because when you are trying to draw current from the load it will come from the M1,then op amp will increase its bias and hence Mo current will also increase, then perfect cancellation of temp coefficients is impossible.
   From your graph at zero current band gap voltage  is at where it has to be.when you are trying to draw current it will increase because of op amp output increment. For convince your self add a dc current source at the load and  see how your voltage will vary with temp,i guess it will vary a lot...
  Another point i am trying to bring out is if you are connecting some thing at one side of the BG,connect other side also , this is the principle behind factional band gap.
Rajasekhar.
