raja.cedt
hi Raags, you should not draw current from the band gap,if you want draw put a buffer and then connect load,because when you are trying to draw current from the load it will come from the M1,then op amp will increase its bias and hence Mo current will also increase, then perfect cancellation of temp coefficients is impossible. From your graph at zero current band gap voltage is at where it has to be.when you are trying to draw current it will increase because of op amp output increment. For convince your self add a dc current source at the load and see how your voltage will vary with temp,i guess it will vary a lot... Another point i am trying to bring out is if you are connecting some thing at one side of the BG,connect other side also , this is the principle behind factional band gap.
Thanks, Rajasekhar.
