Jul 17th, 2024, 11:29pm
Output back-off  requirement for RRC filtered  digital Signal (Read 1718 times)
AnalogAroma
Apr 15th, 2009, 6:25am
Hi Everybody,
        In ourZigbee 868.3 MHz transceiver project  , a RRC filter with roll-off factor 0.2 is used in the transmitter side. The modulation is BPSK with multi-level ASK.  What should be the output power back-off requirement for the power amplifier ? What is the PAPR for this roll-off factor ?
Does anyone know the equation for this back-off relation ?
Re: Output back-off  requirement for RRC filtered  digital Signal
Reply #1 - Apr 15th, 2009, 6:47am
