May 19th, 2024, 11:51pm
Any algo to calculate the randomness of data pattern (Read 6867 times)
neoflash
Mixed-Signal
Designer
Apr 16th, 2009, 8:29pm
I want to build an algo to judge whether input N length pattern is noise like or very repetetive pattern.
Any known reference to recommend?
Neo
Visjnoe
Re: Any algo to calculate the randomness of data pattern
Reply #1 - Apr 17th, 2009, 4:06am
Dear Neo,
the subject of randomness by itself is not as 'trivial' as some people may think. Please have a look at 'Kolmogorov complexity'. In short: there's no general algorithm to proof that your string is random.
Peter
Reply #2 - Apr 17th, 2009, 4:55am
neoflash wrote on Apr 16th, 2009, 8:29pm:
Calculate auto-correlation function and plot it.
Here judgement is dependent on your own thinking.
http://en.wikipedia.org/wiki/Auto_correlation
neoflash
Mixed-Signal
Designer
Reply #3 - Apr 17th, 2009, 8:39pm
pancho_hideboo wrote on Apr 17th, 2009, 4:55am:
When we calculated the Rx vector, how to judge the randomness of the data? I think it is still hard to tell from the Rx vector.
Any suggestions or reference paper?
Reply #4 - Apr 18th, 2009, 12:50am
neoflash wrote on Apr 17th, 2009, 8:39pm:
It depends on your need or thinking for randomness.
Anyway try to plot Rxx[n], n=0,...,N-1 for your target sequences, then consider and make criteria.
« Last Edit: Apr 18th, 2009, 6:59am by pancho_hideboo »
Reply #5 - May 5th, 2009, 12:05am
Hi neo,
What's your need?  What's your application? If you don't have any special  requirement, plot the FFT of the data stream or calculate the auto-correlation as what pancho_hidiboo said. Otherwise, maybe you need to check the run length of continous 0 and 1, the balance between number of 0 and number of 1, etc.
Yawei
Frank Wiedmann
Munich, Germany
Reply #6 - May 5th, 2009, 1:48am
See also http://en.wikipedia.org/wiki/Randomness_tests and the links given there.
neoflash
Mixed-Signal
Designer
Reply #7 - May 5th, 2009, 8:15pm
I think calculating FFT is a good idea. But calculating Rx is more practical a idea and easier to implement.
The statistics could be collected over time and updated in a accumulator.
Thanks.
vivkr
Reply #8 - May 6th, 2009, 1:12am
neoflash wrote on May 5th, 2009, 8:15pm:
Thanks.
That is a strange comment to make since autocorrelation (Rx) and power spectral density (based on FFT) provide identical information, provided that they are used correctly, and ideally both are computed to provide an overview in time- and frequency- domains.
As for computation, I don't believe that one or the other is more difficult. Matlab for instance will give you both in a flash. In the old days, it might have been computationally easier to compute Rx than the FFT but I think those were very old days.
Vivek
