aaron_do wrote on Apr 22nd, 2009, 8:54pm:I guess I should be running a PSS + PAC analysis with a small signal at the RF port, but because the circuit is balanced, I don't expect to see much RF-LO leakage without adding some circuit mismatch. So i'm thinking I need to run a monte-carlo analysis.
I don't use monte-carlo analysis.
aaron_do wrote on Apr 22nd, 2009, 8:54pm:1) Can I simply add statistics to the model file and if so, how can I go about doing that?
Model files of major design kits are very helpful. Here you have to forge parameters.
aaron_do wrote on Apr 22nd, 2009, 8:54pm:2) Does the monte-carlo analysis also include mismatch between transistors which use the same model file?
Yes it does.
aaron_do wrote on Apr 22nd, 2009, 8:54pm:3) Assuming I have to use monte-carlo, does anybody have a good tutorial document on how to go about setting it up?
I don't know.
Maybe the following is not useful at all.
http://cp.literature.agilent.com/litweb/pdf/5990-3609EN.pdfaaron_do wrote on Apr 22nd, 2009, 8:54pm:4) If not monte-carlo, how else can I go about simulating the leakage?
I simulate only worst case for pair mismatch. Here I forge parameters.
