Jul 16th, 2024, 8:21pm
How to simulate RF-LO leakage in a double-balanced mixer (Read 2826 times)
aaron_do
Apr 22nd, 2009, 8:54pm
I want to simulate the RF-LO leakage in a double balanced mixer. Can anybody give me hints on what sort of simulation to run?
I guess I should be running a PSS + PAC analysis with a small signal at the RF port, but because the circuit is balanced, I don't expect to see much RF-LO leakage without adding some circuit mismatch. So i'm thinking I need to run a monte-carlo analysis. Unfortunately, I don't see a statistics block in the model file and when I try to run a monte-carlo analysis I get an error saying there is no statistics block.
So I have some basic questions.
1) Can I simply add statistics to the model file and if so, how can I go about doing that?
2) Does the monte-carlo analysis also include mismatch between transistors which use the same model file?
3) Assuming I have to use monte-carlo, does anybody have a good tutorial document on how to go about setting it up?
4) If not monte-carlo, how else can I go about simulating the leakage?
thanks,
Aaron
Re: How to simulate RF-LO leakage in a double-balanced mixer
Reply #1 - Apr 23rd, 2009, 6:30am
aaron_do wrote on Apr 22nd, 2009, 8:54pm:
I don't use monte-carlo analysis.
Model files of major design kits are very helpful. Here you have to forge parameters.
Yes it does.
I don't know.
Maybe the following is not useful at all.
http://cp.literature.agilent.com/litweb/pdf/5990-3609EN.pdf
I simulate only worst case for pair mismatch. Here I forge parameters.
aaron_do
Reply #2 - Apr 23rd, 2009, 7:33pm
Hi pancho_hideboo,
could you elaborate on how you forge parameters?
thanks,
Aaron
Reply #3 - Apr 23rd, 2009, 11:44pm
For advice on Monte Carlo, check out http://www.designers-guide.org/Modeling/montecarlo.pdf.
