May 18th, 2024, 12:43am
Problem in simulating a Diff.  Switching PA in SpectreRF (Read 5781 times)
AnalogAroma
Apr 23rd, 2009, 5:50pm
Hi  Everybody,
      I am facing some problems in simulating a differential switching power amplifier where  the tail current is modulated by the baseband signal.  I mean, the baseband signal will generate a ref current which will linearly control the tail current which will be  up-converted to the RF frequency  using a LO signal. Similar to a single balanced mixer. The attached pic further clarfies the PA.
Typical simulation techiniques in SpectreRF are suitable for a PA succeeding a mixer where RF input is coming from the mixer.
But, in my case,  LO osc input  does not have any baseband envelope .
And the low freq baseband input cannot use RF port symbol !!!
So, typical way of calculating  1dB compression  point is not suitable.
Is there any way to overcome this problem in SpectreRF ?
Any trick ?
Re: Problem in simulating a Diff.  Switching PA in SpectreRF
Reply #1 - Apr 23rd, 2009, 7:25pm
I can't find out any Design Issue in your questions.  Your questions are simple measurement issue of RF block.
I can't understand what you are confusing.
Your "Switching PA???" is no more than TX-UpMixer or AM-Modulator which have two inputs, LO and BB.
So there is no problem in treating your case by two-tones(LO, BB) or one-tone(LO) steady state analysis.
I don't think your circuit is Switching PA. http://www.designers-guide.org/Forum/YaBB.pl?num=1214811603
AnalogAroma wrote on Apr 23rd, 2009, 5:50pm:
But, in my case,  LO osc input  does not have any baseband envelope.
What do you mean ?
How do you define 1dB compression  point ?
"LO_Input_Level v.s. Output_Level with BB_Input=Constant Level(DC or Sine)"
 or
"BB_Input_Level v.s. Output_Level with LO_Input=Constant Level(Sine)" ?
How do you define output power for modulation output ?
"Averaged Power" or "PEP(Peak Envelope Power)" ?
Usually I simulate simply non-modulation case where BB is DC.
Here I use swept BB of DC source with one-tone(LO) steady state analysis.
If I use sinusoidal signal for BB, I invoke two-tones(LO, BB) steady state analysis.
Here you have to choose which output power you should evaluate. "Averaged Power" or "PEP(Peak Envelope Power)".
This selection is dependent on your needs or interests.
Attached figure is Instantaneous Envelope Power of ASK signal.
http://www.designers-guide.org/Forum/YaBB.pl?num=1209812189
Is there any problem in treating your case by Cadence Spectre ?, although I don't use Cadence Spectre.
« Last Edit: Apr 24th, 2009, 4:51am by pancho_hideboo »
Reply #2 - Apr 23rd, 2009, 11:53pm
SpectreRF does not require the use of ports as sources. It works just as well with voltage sources and current sources.
Reply #3 - Apr 24th, 2009, 4:30am
Ken Kundert wrote on Apr 23rd, 2009, 11:53pm:
Any vendor's RF simulator except for very old one such as "SuperCOMPACT" does not require the use of ports as sources.
Reply #4 - Apr 24th, 2009, 6:39am
Correct, but it's a common misperception amongst users of RF simulators, perhaps because examples are often using ports, and so there is sometimes a mistaken assumption that you must use them.
AnalogAroma
Reply #5 - May 6th, 2009, 10:55am
Tape out date is over. So far, I could not respond to  all the feedback.
Within several days I will try to describe the problems
encountered in the recent tape-out of power amplifier in greater detail.
AnalogAroma
Reply #6 - May 11th, 2009, 10:38am
Although I had attached a CMOS  based PA image, in reality SiGe HBT based PA   was designed.
Reply #7 - May 12th, 2009, 3:54am
AnalogAroma wrote on May 11th, 2009, 10:38am:
What do you want to say ?
Whatever process you use for designing your PA, simulation methods are same.
