Aug 16th, 2024, 6:42pm
source follower channel length modulation effect (Read 1241 times)
LeeX
Singapore
Apr 29th, 2009, 6:37am
I am trying to design a PMOS source follower (simple source follower circuit with two PMOS transistors).
The desired input range is from 0.1 v to 0.6 v.
The problem is, for such a large input range, the channel length modulation effect is quite severe. Because of that, when the input is 0.1 v,  I might get an output of 0.55 v, but when the input is 0.6 v, I might end up with 1 v at the output.
Is there any way to mitigate this problem, other than increasing the transistor length?
