Jul 18th, 2024, 1:21pm
[hspice] .measure'd values in analysis in the same file (Read 1637 times)
samba-r
Apr 30th, 2009, 9:59am
Hi, I've traced many manuals and examples but I can't get nor the direct answer, nor a useful example for the following question for HSPICE: can one use .measure'd values in an analysis in the same file.
For example, I want to find the operating point for a device (linear region on its transfer function), i.e. a neighbourhood around the input voltage where the derivative of the output voltage is at its maximum.
Then I want e.g. to do another analysis around that point, that is I need to use the found input voltage value as a parameter of the analysis directive.
Then I want e.g. to do AC analysis at that operating point. For that reason I supposingly need to shift the input voltage source by the found value of the input voltage, that is I need to use the found value as a parameter in the voltage source expression.
Is it possible to do all these things automatically, i.e. without one's own intervention and cnanging the netlist?
Thanks in advance,
samba
spiceoracle
USA
Re: [hspice] .measure'd values in analysis in the same file
Reply #1 - May 7th, 2009, 3:34pm
.MEASURE statements is a post processing function and the results cannot be used in the same simulation.
Forgive me if I'm not understanding what you want to do correctly, but this sounds similar to an optimization and you might want to consider setting up an optimization.
