samba-r
Hi, I've traced many manuals and examples but I can't get nor the direct answer, nor a useful example for the following question for HSPICE: can one use .measure'd values in an analysis in the same file.
For example, I want to find the operating point for a device (linear region on its transfer function), i.e. a neighbourhood around the input voltage where the derivative of the output voltage is at its maximum. Then I want e.g. to do another analysis around that point, that is I need to use the found input voltage value as a parameter of the analysis directive. Then I want e.g. to do AC analysis at that operating point. For that reason I supposingly need to shift the input voltage source by the found value of the input voltage, that is I need to use the found value as a parameter in the voltage source expression.
Is it possible to do all these things automatically, i.e. without one's own intervention and cnanging the netlist?
Thanks in advance, samba
