Aug 16th, 2024, 4:24pm
phase noise questions? (Read 4985 times)
liletian
MD
May 04th, 2009, 8:49am
 Hi Guys
 I had a measured results shows the following spectrum of ring oscillator, it seems the spectrum is dirty, any suggestions what the phase noise source might be?  I do not think it is flicker noise since it is at the 10Mhz region, am I right? Also, is their paper or post about VCO layout techniques? I would like to make a PLL, but I want to isolate VCO from mixer and amplifier stage if possible.
Re: phase noise questions?
Reply #1 - May 4th, 2009, 8:53am
liletian wrote on May 4th, 2009, 8:49am:
It is not suprised at all that spectrum is dirty because your ring oscillator is free running state.
But I can't figure out your situations any more with only spectrum.
How to probe signal ?
What instruments do you have and use ?
Can you measure envelope_amplitude v.s. time ?
Can you measure Frequency Deviation v.s. time ?
liletian
MD
Reply #2 - May 4th, 2009, 9:05am
pancho_hideboo wrote on May 4th, 2009, 8:53am:
Can you explain more free running state?
In which state it will be better spectrum?
 how yo measure envelope_amplitude v.s. time ?
 what's the use of it?
 I use agilent spectrum analysizer to measure it and GSG probe.
Reply #3 - May 4th, 2009, 9:11am
It seems you don't have much experiences of actual measurements.
liletian wrote on May 4th, 2009, 9:05am:
It is "not locked state".
You don't seem to understand VCO, PLL, etc.
There are many spectrum analyzer in Agilent.
http://www.home.agilent.com/agilent/product.jspx?nid=-536902453.0.00&cc=US&lc=en...
But I think your spectrum analyzer have built-in VSA89600 Vector Signal Analysis ability. Is it right ?
how yo measure envelope_amplitude v.s. time ? Frequency Deviation v.s. time ?
Use VSA89600 Vector Signal Analysis.
You can distinguish AM-Noise and PM(FM)-Noise.
and GSG probe.
I don't mean what probe you use.
It seems 50ohm is loaded directly in your observation point of circuit.
Your observation point of circuit have enough ability to drive load of 50ohm ?
Does it require high-impedance probing, such as Giga-Pico-Probe ?
« Last Edit: May 4th, 2009, 10:57am by pancho_hideboo »
liletian
MD
Reply #4 - May 5th, 2009, 8:08pm
pancho_hideboo wrote on May 4th, 2009, 9:11am:
so for unlocked state, the spectrum is very dirty?
I do, I read a lot books, but not as much experience yet.
yes, I did not use this feather yet.:)
 Thanks, I will read manual and try to do it.
and GSG probe.
yes, definitely!
no, for oscillator point, we did not need it!
Reply #5 - May 6th, 2009, 8:55am
liletian wrote on May 5th, 2009, 8:08pm:
Not so dirty as your spectrum. Your spectrum is very dirty.
And floors of your spectrum are very high and dirty.
I suspect PSRR(POwer Supply Rejection Ratio) of your VCO.
Is PSRR of your VCO enough large ?
You should consult someone who has much experience of actual RF measurements about your measurement setups and usages of instruments.
??? feature ?
liletian
MD
Reply #6 - May 6th, 2009, 9:08am
pancho_hideboo wrote on May 6th, 2009, 8:55am:
Anyway floors of your spectrum are very high and dirty.
??? feature ?
function Sad
Reply #7 - May 6th, 2009, 11:04am
liletian wrote on May 6th, 2009, 9:08am:
??? feature ?
function Sad
Unbelievable typo !!
