neoflash
![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif)
![](http://avatar.elektroda.net/gallery/00fun/download.php-1072.gif)
Mixed-Signal Designer
Signal detection level of serial transceivers is from 65mV-ppd to 175mV-ppd, with 120mV-ppd as nominal detection threshold. (PCIE Gen2)
However, if the data pattern is clock and if there is 20dB attenuation at baud rate, the signal amplitude will be close to 1/10 of transmitter side full amplitude.
Assuming Tx amplitude is 1200mV-ppd, the rx side amplitude is 1/10 and close to 120mV-ppd. This signal will be rejected by input signal detector and chip will enter electrical idle.
How we handle this?
