May 9th, 2024, 10:46am
Optimum Bias current value for MDAC in PipelineADC (Read 4268 times)
Mahesh
ahmedabad
May 12th, 2009, 11:35pm
I am working on 1V 12 bit Pipeline ADC @ 80 MSPS design.I am badly stuck in finding out the optimum value for the bias current(tail current source) for the OTA used in the 2-bit/stage MDAC(Multiplying DAC).Kindly help me out.
kidman
Re: Optimum Bias current value for MDAC in PipelineADC
Reply #1 - Sep 13th, 2009, 1:29am
It all depends on the specs of the OTA. You can use the gm/id method
http://bwrc.eecs.berkeley.edu/classes/icdesign/ee240_s09/
raja.cedt
Reply #2 - Sep 13th, 2009, 4:29am
hi,
   i didn't understand what do you mean by optimal..generally for getting required bandwidth bias current will be fixed.
rajasekhar
RobG
Bozeman, MT
Reply #3 - Sep 13th, 2009, 12:10pm
raja.cedt wrote on Sep 13th, 2009, 4:29am:
hi,
rajasekhar
This has been my experience... current is set by the load capacitance, and load capacitance is set by the desired noise.
raja.cedt
Reply #4 - Sep 14th, 2009, 1:23am
hi,
   if you fix gm for noise reduction how you will get desired bandwidth?
rajasekhar.
RobG
Bozeman, MT
Reply #5 - Sep 15th, 2009, 2:50pm
raja.cedt wrote on Sep 14th, 2009, 1:23am:
hi,
I can't tell if this was in response to my comment so let me expand. In an MDAC there are 2 major sources of noise: 1) Thermal noise from the opamp and 2) thermal noise from the sampling switch (i.e. kT/C noise).  To decrease opamp thermal noise you need to increase the current. To decrease the kT/C noise you increase the capacitance. But by doing this you ALSO have to increase the opamp current so that it can drive the additional load capacitance.
So regardless of the noise source you have to increase the opamp current.
With MDACs it has been my experience that kT/C noise dominates. This means the design flow is: 1) Pick sample cap size based on kT/C noise. 2) pick opamp current based on need to drive the sample cap.
So, to optimize you should choose the caps sizes, which determines the current. Not vice-versa.
FWIW Chiu/Gray's 2004 JSSC work touches on optimizing MDAC scaling on down the pipeline.
