Jul 17th, 2024, 12:29am
Transistor level design in " Cadence " (Read 932 times)
An_Enginner_In_d_Making
May 15th, 2009, 9:59am
I am trying to Optimize an Amplifier Circuit using Cadence.
I need some way to calculate threshold voltage of a transistor and use it in the Optimizer tool.
eg. I have to define an Output X , where X = Vgs(M1) - Vth(M1)
Can someone please tell me how to get the Vth(threshold voltage) for a transistor in Cadence ?
Thank You for your help.
cmos.analogvala
India
Re: Transistor level design in " Cadence "
Reply #1 - May 16th, 2009, 2:49am
Do operating point analysis(DCOP) and print operating point of a transistor in cadence ...
-CA
Reply #2 - May 16th, 2009, 4:22am
An_Enginner_In_d_Making wrote on May 15th, 2009, 9:59am:
I don't know what you mean by Cadence. There is no tool which name is Cadence.
If you mean Cadence Spectre under Cadence ADE, see http://www.eecs.tufts.edu/~ryun01/gmid_ruida.pdf
Also see "pv()" function of OCEAN.
pv( t_name t_param [?result s_resultName [?resultsDir t_resultsDir]] ) => g_value/nil
[Description]
Returns the value for the specified component parameter. You can use the outputParams command to get the list of parameters for a particular component.
[Arguments]
t_name Name of the node or component.
t_param Name of the parameter.
s_resultName Results from an analysis.When specified, this argument will only be used internally and will not alter the current result which was set by the selectResult command.
The default is the current result selected with the selectResult command.
t_resultsDir Directory containing the PSF files (results).
If you supply this argument, you must also supply the resultName argument.
When specified, this argument will only be used internally and will not alter the current results directory which was set by the openResults command.
The default is the current results directory set by the openResults command.
[Value Returned]
g_value Returns the requested parameter value.
nil Returns nil and prints an error message.
[Examples]
selectResult( ’dcOp )
pv( "/Q19" "ib" )
For the Q19 component, returns the value of the ib parameter.
pv( "/Q19" "ib" ?resultsDir "./test2/psf" )
For the Q19 component, returns the value of the ib parameter for the results from a different run (stored in test2/psf).
pv( "/Q19" "ib" ?result "dcOp" ?resultDir "./test1/psf")
Returns the value of the ib parameter for the Q19 component for the dcOp results stored at the location ./test1/psf.
« Last Edit: May 16th, 2009, 9:48pm by pancho_hideboo »
