jqjqjq
Hi,raja, I have the same intuition with you from Allen's book. For your question, I think that op amps is designed in the way that the first stage gives the dominant pole and the second stage give the non-dominant one, just as the first stage is always the transconductance stage and the second be buffer with high output current. If what you assumed happen, we should use other ways to compensate the opamp and perhaps Miller compensation will fail. Hope helpful. Best regards. jqjqjq
