Aug 15th, 2024, 10:20pm
bmslib in cadence university suite (Read 6521 times)
cmos.analogvala
India
May 22nd, 2009, 11:35pm
We do not have "bmslib" library with the present cadence icfb(IC5141) tool set. I think bmslib is a powerful lirary  for measurements  similar to analogLib for sources and basic components ?
We have cadence university package with us.
The questions are:
Is my understanding about cadence bmslib correct ?
How to get bmslib in cadence university package ?
Please reply
-CA
Re: bmslib in cadence university suite
Reply #1 - May 29th, 2009, 1:05am
Really? It's installed whenever spectre is installed as part of the IC5141 products (product 32500, 32520 or 90001). So I'd be very surprised if its not there.
It should be in <ICinstDir>/tools/dfII/samples/artist/bmslib
cmos.analogvala
India
Reply #2 - May 29th, 2009, 11:47pm
Thanks a lot ..BMSlib is present in the above mentioned location...
When do we use ahdl lib and when do we use bmslib ?
-CA
Reply #3 - Jul 10th, 2009, 6:37am
Which library to use depends on what model you want! These are sample model libraries, the idea is you can take your pick. You can use both if you like, or copy models from either library into your own, and modify them.
