Berti
I think it is ok to route metal lines underneath a MIM capacitors, if you can except the increased bottom plate capacitance and risk of coupling. But q3 was referring to shielding what you can do, but is not necessary.
The use of M5/M6 below the MIM is probability prohibited by the fab since it might results in a short in fabrication.
