May 18th, 2024, 10:27pm
The LNA input impedance matching (Read 6432 times)
NeilYu
Jun 05th, 2009, 9:28pm
Hi,all!
Why we all designed the LNA to have a 50ohm input impedance if we consider the LNA as a Voltage amplifier?
in my opinion,to get the maxium SNR(or the minimum NF) in the output terminal of the receiver,we can design a LNA with infinite input impedance.So what's wrong with this?
Thanks!
NeilYu
Re: The LNA input impedance matching
Reply #1 - Jun 8th, 2009, 2:42am
NeilYu wrote on Jun 5th, 2009, 9:28pm:
Your wrong thought is due to ignorance of currents.
http://www.designers-guide.org/Forum/YaBB.pl?num=1212573477/7#7
You can never realize both zero and infinite output/input impedance.
« Last Edit: Jun 8th, 2009, 5:31am by pancho_hideboo »
RFICDUDE
Reply #2 - Jun 9th, 2009, 7:55pm
It is an interesting point.
At low frequency, CMOS devices do have nearly infinite input impedance and very high voltage gain. The noise contribution of the device is generally thought of as an additive noise current, so the higher the voltage gain the lower the input referred noise. This viewpoint seems valid for low/medium frequency ranges and is only limited by the achievable voltage gain versus the noise current.
Unfortunately, really high voltage gain requires active loads which have much worse noise performance than a passive resistor load, so there is a trade off between achievable gain and additive noise.
At high frequencies, this approach has to be moderated because the input is not high impedance because of the input capacitance. The only logical thing to do is to resonant out the input capacitance, but still the input impedance is not nearly as large as it is at low frequency. Moreover, the real part of the input is very small making it difficult to match to a fixed input impedance (inductive source degeneration is needed).
So, in summary, at low frequencies you cannot achieve very high gain with lower noise passive resistor loads. With active (noisy) loads high gain is achieavable at the expense of excess noise. At high frequencies, really high gain is not practically achievable and the optimal impedance to maximize SNR is far from an open or short.
Ian
Reply #3 - Jun 17th, 2009, 4:16am
I guess it should also be related to the antenna design. If the LNA and antenna are co-designed (the interconnection in between is very short), and the antenna is OK with a large-impedance load, I think an input impedance matching is not a must.
Reply #4 - Jun 17th, 2009, 8:10am
