Jul 16th, 2024, 10:26pm
Pnoise analysis of PFD+Charge Pump (Read 7881 times)
sanjay
Jun 09th, 2009, 4:07am
I am doing pnoise analysis for PFD+Charge pump.
Setup is as shown in fig(1):
and      commands used are:
        TT_pss  pss  fund=10M  harms=5  errpreset=moderate
     +    tstab=2u  annotate=status
     TT_pn   pnoise  sweeptype=relative   oprobe=V7
     +       start=100  stop=10G  maxsideband=5  annotate=status
But, when I am plotting phase noise, it is giving following error:
*Error* quotient: can't handle (nil / 1.414214)
Can any one help me?
Thanks...
Re: Pnoise analysis of PFD+Charge Pump
Reply #1 - Jun 9th, 2009, 5:03am
sanjay wrote on Jun 9th, 2009, 4:07am:
What vendor's simulator do you use ?
There are many simulators which have analysis called as Pnoise.
I assume Pnoise of Cadence Spectre under Cadence ADE.
Show me output equation.
You can get it by enabling "Add Output" if you use Direct Plot Form of ADE,
sanjay
Reply #2 - Jun 9th, 2009, 6:25am
I am using spectreRF for simulation & ocean script to plot phase noise as below:
openResults("test.raw")
pn=phaseNoise(1 "pss_fd" ?result "pnoise")
plot(pn)
Thank you...
Reply #3 - Jun 9th, 2009, 6:44am
Try to modify analysis statements like following.
Quote:
TT_pss  pss  fund=10M  harms=1  maxacfreq=100M errpreset=moderate
+   tstab=2u  annotate=status  outputtype=all
TT_pn  pnoise  oprobe=V7  maxsideband=7
+   sweeptype=relative relharmnum=1
+   start=100  stop=10G  dec=5 annotate=status
sanjay
Reply #4 - Jun 9th, 2009, 7:45am
Pancho,
Thank you for your precious time.
I tried the code you mentioned but it is giving the same error....
Reply #5 - Jun 9th, 2009, 8:12am
sanjay wrote on Jun 9th, 2009, 7:45am:
Try to change current probe "V7" to "CCVS".
Then observe output as node voltage.
lunren
Asia
Reply #6 - Aug 6th, 2009, 9:34am
I think the sweettype should be "absolute", not "relative". When we simulate VCO, we use "relative" because we want to get the phase noise of VCO. Concerning PFD+Charge Pump, we want to get noise current, which is not relative to fun frequency.
Lunren
Forum Administrator
YaBB Administrator
Reply #7 - Aug 10th, 2009, 10:05am
The error message does not look like it is from Spectre, meaning it is probably from Ocean. Since is is complaining about data that is 'nil', it likely means that the data does not exist for some reason. Check the simulation log file and make sure the simulation completed without error and the results were produced.
