Aug 17th, 2024, 10:23am
How to do a distortion Analysis of a Differential Amplifier? (Read 350 times)
saket
Jun 12th, 2009, 4:01am
I am looking for ways to reduce the third harmonic from the output of a differential amplifier. Are there any papers detailing distortion analysis? any good books which relate to this topic that anyone can recommend?
Any help will be deeply appreciated!
buddypoor
Bremen, Germany
Re: How to do a distortion Analysis of a Differential Amplifier?
Reply #1 - Jun 15th, 2009, 7:02am
The simplest method is certainly to reduce the level of the input signal because THD gets larger when the output voltage swing is large.
LvW
sos
Reply #2 - Jun 23rd, 2009, 4:55am
A possibly more useful response...
Distortion can occur throughout the circuit, but it is likely to be either at the input or at the output. Improving distortion first requires deciding where the dominant source is.
Odd harmonic distortion is often caused by output load currents. Change the load impedance and see what happens.
Output distortion is often dependent on output stage bias current. Try experimenting with the bias.
Input distortion in a feedback amplifier implies that you have too much error voltage applied to the input stage, given its construction. Higher bias current can help, you can also improve distortion by degenerating the input, but these also change open loop gain.
In a feedback amplifier, higher open loop gain will usually decrease distortion whether the source is at the input or output. The trick, of course, is how to increase the open loop gain and retain stability.
Steve
raja.cedt
Reply #3 - Jun 23rd, 2009, 7:55am
hi,
 1.how can you say that odd harmonics  depends on output load current
2.Increasing loop gain will reduce distortion but what i saw in many cases it is limited by  many other parameters like PM,settling time....
Rajasekhar.
Reply #4 - Jun 23rd, 2009, 9:56am
raja.cedt wrote on Jun 23rd, 2009, 7:55am:
1. how can you say that odd harmonics depends on output load current
This changes a load line for output transistor, so it is quite natural that odd harmonics depends on output load current.
sos wrote on Jun 23rd, 2009, 4:55am:
« Last Edit: Jun 24th, 2009, 4:49am by pancho_hideboo »
Berti
Reply #5 - Jun 24th, 2009, 6:20am
Quote:
raja.cedt wrote on Yesterday at 7:55am:
I am not convinced that this statement is generally true. Saket didn't give any details. What is the load current in a SC circuit?
I agree with most of the answers but I wouldn't recommend to try improving the distortion by trial-and-error. Take a look at the following paper: G. Palumbo and S. Pennisi, High-frequency harmonic distortion in feedback amplifiers, IEEE Trans. Circuits and Systems, March, 2003.
They provide a mathematical framework to do distortion analysis without the need for complicated Volterra series. Maybe you gain more insight this way.
Good luck!
Reply #6 - Jun 24th, 2009, 6:25am
Berti wrote on Jun 24th, 2009, 6:20am:
Who refers to SC circuits in this thread ?
And even for SC circuits, we can define load line and current.
raja.cedt
Reply #7 - Jun 24th, 2009, 6:26am
hi,
  lets say my opamp is driving a voltage buffer, does it mean opamp output don't have odd harmonics? (i am asking this based on the previous ans ...load current will create odd harmonics , in this scenario opamp is not driving any load current )
Rajasekhar.
Reply #8 - Jun 24th, 2009, 6:31am
raja.cedt wrote on Jun 24th, 2009, 6:26am:
Output impedance of OPAmp is not zero actually.
And apart from final output of OPAmp, there are loads in voltage gain stages in every OPAmp.
aaron_do
Reply #9 - Jun 24th, 2009, 7:10am
I think you can look at a basic single stage CMOS amplifier as a V-I converter (diff pair for example) followed by a I-V converter (the load + output resistance). Both the V-I and the I-V converters will be nonlinear and will create odd harmonics.
cheers,
Aaron
Reply #10 - Jun 24th, 2009, 7:16am
aaron_do wrote on Jun 24th, 2009, 7:10am:
I think odd harmonics of V-I converters is dominated by input nonlinearity not output.
sos
Reply #11 - Jun 24th, 2009, 8:54am
hi,
I'm assuming that the output stage has push and pull capability. If a signal distorts similarly for positive and negative signals, that shows up in the spectrum as odd harmonics.
Increasing loop gain doesn't always work, but sometimes it is easy to try.
Rajasekhar.
sos
Reply #12 - Jun 24th, 2009, 8:56am
hi,
Rajasekhar.
My suggesting output load current assumed you had a load. If there is no load, other sources of distortion are at fault.
Steve
Berti
Reply #13 - Jun 24th, 2009, 11:28pm
I think we are talking all about more or less the same. But people are providing different explanations since Saket didn't specify whether "amplifier" refers to an OTA or an OpAmp, and its is not clear whether he drives resistive or capacitive loads/feedback or open-loop etc.
Maybe Saket can clarify that point.?
Cheers
