raja.cedt
hi, thats mainly in your hand only, i guess this is a first stage of an comparator, so based on the input resolution you might have some gain and you know how much time in your hand for first stage so based on that how much gm you need and for that gm you can find how much current in the input differential pair and double of that current is what you want.Listen this is the not only the way... Thanks, rajasekhar.
