Aug 16th, 2024, 6:23pm
How to calculate bias current (Read 345 times)
icekalt
Aalen, Germany
Jun 15th, 2009, 5:45am
Can someone explain@help to determine the value of Ibias? You can find the circuit in the attachment. VDD is 3.3V and the MOS technology used is 0.35µm.
thx in advanced
raja.cedt
Re: How to calculate bias current
Reply #1 - Jun 15th, 2009, 6:03am
hi,
   thats mainly in your hand only, i guess this is a first stage of an comparator, so based on the input resolution you might have some gain and you know how much time in your hand for first stage so based on that how much gm you need  and for that gm you can find how much current in the input differential pair and double of that current is what you want.Listen this is the not only the way...
rajasekhar.
Reply #2 - Jun 15th, 2009, 6:12am
icekalt wrote on Jun 15th, 2009, 5:45am:
As draft design, you can determine Ibias if you determine required intrinsic gain and required slew rate and load capacitance.
raja.cedt
Reply #3 - Jun 15th, 2009, 6:31am
hi,
  i forgot to ask ,how did you come up with diff amp w/l ratio,don't you consider current in that case?
Rajasekhar.
icekalt
Aalen, Germany
Reply #4 - Jun 15th, 2009, 6:49am
raja.cedt wrote on Jun 15th, 2009, 6:31am:
hi,
Rajasekhar.
i just randomly selected it..:)
icekalt
Aalen, Germany
Reply #5 - Jun 15th, 2009, 6:56am
pancho_hideboo wrote on Jun 15th, 2009, 6:12am:
hello pancho_hideboo,
are you referring the load capacitance to the diode connected loads(two PMOS)?
Reply #6 - Jun 15th, 2009, 7:09am
icekalt wrote on Jun 15th, 2009, 6:56am:
Right although they are not diode connected loads.
http://www.zen118213.zen.co.uk/RFIC_Circuits_Files/MOS_OP-Amplifier_Intro.pdf
http://www.zen118213.zen.co.uk/RFIC_Circuits_Files/MOS_OP-Amplifier_Example.pdf
uu@uk
Reply #7 - Jun 15th, 2009, 8:30am
What is the amplifier for? If it is driving capacitors and you need high swing at the output. The slew rate may also give you some idea about the bias current.
uu@uk
HdrChopper
Reply #8 - Jun 15th, 2009, 1:20pm
On top of what was already suggested, also input noise and offset levels might be controlled by means of Ibias.
Tosei
Keep it simple
icekalt
Aalen, Germany
Reply #9 - Jun 16th, 2009, 5:34am
uu@uk wrote on Jun 15th, 2009, 8:30am:
uu@uk
thx uu@uuk.  The amplifier is for the comparator. It has to amplify the difference of two signals.
icekalt
Aalen, Germany
Reply #10 - Jun 16th, 2009, 5:37am
What is the best analysis to simulate that circuit? transient or ac or dc sweep??
icekalt
Aalen, Germany
Reply #11 - Jun 16th, 2009, 5:44am
pancho_hideboo wrote on Jun 15th, 2009, 7:09am:
halo pancho_hideboo,
I just have read through the documents. Do you have example for differential amplifier used in comparator? the one that you give me is used in op-amp..thx
uu@uk
Reply #12 - Jun 16th, 2009, 10:14am
icekalt wrote on Jun 16th, 2009, 5:37am:
If your amplifier is for a comparator, I think you need both transient and DC analysis. transient could tell you the rise/fall edge rate. DC analysis can check the FETS are all working in the right region. good luck.
icekalt
Aalen, Germany
Reply #13 - Jun 17th, 2009, 7:15am
uu@uk wrote on Jun 16th, 2009, 10:14am:
Thx uu@uk. Can you explain me more about rise/fall edge? How to know if our MOS transistors working in the right region based on simulation? thx
