Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 18
th
, 2024, 6:23pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› MOSCAP
Previous topic
Next topic
MOSCAP (Read 1623 times)
raja.cedt
MOSCAP
Jul 08
th
, 2009, 4:12am
hi,
can any body please tell me why moscap is made in N substrate (i knew that we can connect nmos drain and source and it works well, in that case it will be P substrate)
rajasekhar.N
IP Logged
solidstate
Munich, Germany
Re: MOSCAP
Reply #1 -
Jul 8
th
, 2009, 2:19pm
As far as I know, this allows for the moscap to have a dedicated ground terminal; without the nwell, the bottom plate of the moscap would be the substrate, so substrate noise (e.g. from digital logic) could then be coupled in..
IP Logged
raja.cedt
Re: MOSCAP
Reply #2 -
Jul 8
th
, 2009, 9:46pm
hi,
thats fine but they could have put pwell right because then it works like nmos then we can connect Drain and Source..
rajasekhar.
IP Logged
shashi.kiran
india
Re: MOSCAP
Reply #3 -
Jul 9
th
, 2009, 4:39am
if ur using NMOS -CAP it has to be p-sub and PMOS CAP it has to be n-well ..!!..i dont think we use Nmos and n-type substrate ..!!
IP Logged
Dipankar
Re: MOSCAP
Reply #4 -
Jul 9
th
, 2009, 7:01am
Dear All,
N-Moscap in nwell means you need very low gate voltage to send the device into strong inversion. So the C-V does not have accumulation region . With this kind of C-V (monotonic) a VARACTOR is realized. They call it NMOSCAP-VARACTOR.
With Thanks and Regards,
Dipankar.
IP Logged
raja.cedt
Re: MOSCAP
Reply #5 -
Jul 9
th
, 2009, 9:24am
hi,
i donno weather i am complicating this question or not, but what i thought is it is like having n diffusion's in nwell,so how inversion will come..i think it will be in accumulation only and works for +ve voltage
Rajasekhar.
IP Logged
shashi.kiran
india
Re: MOSCAP
Reply #6 -
Jul 9
th
, 2009, 9:40pm
@ raja
if you apply +ve gate voltage ...how can u say its in accumulation ??...infact it will be inverted ....i guess dipankar got it right ...it should be in inversion with less gate voltage.
IP Logged
raja.cedt
Re: MOSCAP
Reply #7 -
Jul 9
th
, 2009, 10:18pm
if you apply +ve voltage it will attract all electrons from nwell..so this is accumulation..how inversion will come?
IP Logged
Dipankar
Re: MOSCAP
Reply #8 -
Jul 10
th
, 2009, 7:00pm
Dear Raja,
The crux is nmoscap in nwell gives a monotonic CV curve. That's the motivation behind the structure - creating a mos-varactor.
Dipankar.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
