Jul 16th, 2024, 9:06am
VCDL Verilog-A/AMS Model (Read 4008 times)
Ahmed Nassar
Jul 11th, 2009, 11:36am
Can anyone kindly provide me with a Verilog-A/AMS model of a voltage-controlled delay line?
I know this is a DISTRIBUTED component, but there might be a good lumped-model approximation for it.
Ahmed
Ahmed Nassar
Re: VCDL Verilog-A/AMS Model
Reply #1 - Jul 19th, 2009, 6:07am
I found the solution:
One can use the Verilog-A "delay()" function or the Verilog-AMS "absdelay()" function with the maxdelay parameter passed properly and letting the delay value be varying.
The maxdelay parameter is the key to let the delay value passed to this function be varying. If this parameter is not specified, the delay introduced by either of those functions is not allowed to vary. It seems that maxdelay is used to allocate a fixed amount of buffer space in memory to store all signal values in the delay interval.
