Jul 16th, 2024, 8:42am
Frequency Resolution of a PLL is bound by timescale of VerilogAMS - advice? (Read 2989 times)
Alexander Eßwein
Erlangen, Germany
Jul 15th, 2009, 4:42am
I'm working on a PLL design with behavioral models in VerilogAMS. I encountered a problem where it seems that the minimum timescale of 1 fs is not accurate enough to generate the exact desired frequency of my VCO.
The tuning voltage of my VCO does not get integrated to the precise value I need - namely 0V for a frequency of exactly 5.8 GHz (25MHz Fref, N = 232).
Is there any way to improve the frequency resolution by maybe circumventing the minimum timescale?
Thanks in advance,
Alexander Eßwein
`timescale 1ps / 100 fs
`include "disciplines.vams"
module vco_1 (out_rf, out_div, ps, ns);
parameter real f0 = 5.8G from (0:inf);	// center frequency (Hz)
// parameter real fmax = 6.3G from (0:inf);
// parameter real fmin = 5.3G from (0:inf);
parameter real kvco = 25M;			// gain (Hz/V)
parameter real maxcount = 232;
input ps, ns;
//input DCO_CONTROL_S;
output out_rf, out_div;
electrical ps, ns;
//logic [7:0] DCO_CONTROL;
// logic DCO_CONTROL;
//logic DCO_CONTROL_S;
reg out_rf;
logic out_rf;
reg out_div;
logic out_div;
real vin;
// real din;
integer count;
real freq;
initial begin
	out_rf = 0;
	out_div = 0;
	count = 0;
end //initial
always begin
	vin = V(ps, ns);
	#((0.5e12 / (f0 + kvco * vin))) begin
		out_rf = ~out_rf;
	end //delay
// DIV frequency generation by means of a counter
always @(posedge out_rf or negedge out_rf) begin
	freq = f0 + (kvco * vin);
	count = count + 1;
	if (count == maxcount) begin
		out_div = ~out_div;
		count = 0;
	end //if
end //posedge OUT_RF
jbdavid
Re: Frequency Resolution of a PLL is bound by timescale of VerilogAMS - advice?
Reply #1 - Jul 16th, 2009, 5:58pm
you'll either have to work with Analog side signals, or
delve into the source code for the simulation and add the "as" timescale resolution I first requested from cadence years ago..
not using a simulator with available source code?
File another bug report with the Cad guys.. they'll try to complain that "as" timescales are not in the Language spec. and it'll take years to get a change to the language spec..
there is one other way to do it..
the math to calculate the desired period doesn't drop digits..
you can track the error in the period, and, when it accumulates to at least the minimum timescale, add it back in..
as long as stays under your jitter sensitivity you should be ok..
you'll get the right Average frequency .. by dithering the (quantized) instantaneous frequency around the desired value with the right duty cycle.
good luck!
"burned already"
jbd
jbdavid
