AnalogAroma
Hi Everybody,
In the spec of Transmission spectrum mask ofZigbee, the power at 300K offset from fo = 868MHz should be -36 dBm/100 KHz or -86 dBm/Hz.
However, when we do PSD or FFT in Cadence Spectre or MATLAB, we get a PSD output per Hz. So, for comparison with FFT results, I should use the figure -86 dBm/Hz.
Am I right ?
