May 19th, 2024, 11:15am
PNoise : No crossing events detected for Jitter Calculations (Read 4520 times)
rajat
Jul 16th, 2009, 8:10am
Hello everyone,
I have been trying to calculate Jitter of a MM-Divider using PSS+PNoise analysis in SpectreRF. But, after the PSS analysis runs through successfully (at least I hope so), I get the following error during PNoise analysis.
PNoise analysis : No crossing events detected for Jitter Calculations.
I have no clue as to why this happens, as I can see the PSS solution converging within 3 iterations with the PSS-transient analysis results as shown in the attached pic. The threshold is set to 2.4 V and as can be seen is clearly being crossed.
The MMD is based on CML. And I have the following settings for the analysis:
PSS -
 Beat Frequency = 50M (the divided output frequency)
 No of Harmonics = 7
 Accuracy Defaults : I tried with both conservative & moderate, but without success.
 tstab = 200 ns
PNoise -
     Sweep Type = relative
     Relative Harmonic = 1
     Sweep Range = 100Hz - 25 MHz
     Sweep type = Logarithmic, Points per decade = 7
     Max Sideband = 30
     Output = \out & \outn, as I have the inverted divided signal also available
     Input Source = none
     Noise Type : Jitter
     Threshold Value : 2.4 V
     Crossing Dir = Rise
I would really appreciate some help on this.
Thanks in advance & Regards
Re: PNoise : No crossing events detected for Jitter Calculations
Reply #1 - Jul 16th, 2009, 8:26am
Since you are monitoring a differential signal, shouldn't the threshold be 0?
Why are you using a relative sweep in PNoise?
