Oct 21st, 2024, 1:24pm
Help with DDR LDO (Read 2465 times)
refugee
Help with DDR LDO
Jul 21st, 2009, 5:44am
My recent work is to design a LDO for DDR I II III. Now I meet some problems. Please give me some advise.
The design aim is to design a LDO that can both sink and source current (+/- 10mA). The output voltage range is 0.75V ~ 1.25V, the output cap is 100nF (So, the output should set as the main pole), the output voltage accuracy is +/- 10mV
Because the system could both source and sink current, So, I want to know how to design a circuit that control which loop turn on
Thank you for your help
Re: Help with DDR LDO
Reply #1 - Sep 24th, 2009, 6:12pm
It sounds like a DDR output driver, not like a LDO. Smiley
Yawei
raja.cedt
Reply #2 - Sep 24th, 2009, 10:05pm
hi,
   you have specifications with you right, then start fix loop gain based on settling and you have given accuracy 10mv now find open loop gain
Rajasekhar.
Reply #3 - Sep 29th, 2009, 11:12am
This is not an LDO - its better known as an OTA (Operational Transconductance Amplifier)
