refugee
My recent work is to design a LDO for DDR I II III. Now I meet some problems. Please give me some advise. The design aim is to design a LDO that can both sink and source current (+/- 10mA). The output voltage range is 0.75V ~ 1.25V, the output cap is 100nF (So, the output should set as the main pole), the output voltage accuracy is +/- 10mV
Because the system could both source and sink current, So, I want to know how to design a circuit that control which loop turn on
Thank you for your help
