May 11th, 2024, 10:30pm
Pnoise: RC relaxation oscillator simulation, results dependent on TStab (Read 48 times)
Xiao Wang
Jul 25th, 2009, 9:25pm
I'm designing a low frequency relaxation oscillator in Cadence spectre, using the new augumented pnoise algorithm and the shooting algorithm.  This oscillator is highly nonlinear with a really slow chargeup for roughly 6.6us duration and a extremely fast falling edge of about 1.1ns. The RC oscillator charges up from roughtly -5mV to 315mV on node "Va". I have been able to get pss to converge with the following parameters:
       'reltol  "3e-6"
       'vabstol "1e-8"
       'iabstol "1e-12"
as well as setting the parameters to
?lteratio "10" ?steadyratio "0.001"
in the pss options. These settings are well above the cadence defaults for the "conservative" setting.
I have noticed that the pnoise simulation gives different results depending on where in the period the pss simulation starts. I wrote an ocean script that picks a different Tstab every simulation run and I tell it to output the phase noise results at f0 / 20. These are the results:
(("104.5u"
       ("Va" 0.1467503 65449.94 "VmidP" 0.9907851
           -8190.086
       ((7.110502e-11 8.277806e-15) 9.632774e-10 -101.481)
   ("104u"
       ("Va" 0.1131296 68866.95 "VmidP" 0.9932706
           -2764.549
       ((4.096261e-10 7.753837e-15) 2.312038e-09 -93.87612)
   ("103.5u"
       ("Va" 0.07777253 72403.28 "VmidP" 0.993957
           -428.1294
       ((1.607232e-08 5.677848e-15) 1.44824e-08 -77.93921)
   ("103u" "Error")
   ("102.5u" "Error")
   ("102u"
       ("Va" 0.2978443 44353.19 "VmidP" 0.6551509
           -424485.7
       ((1.793918e-11 7.262696e-15) 4.838403e-10 -107.462)
   ("101u"
       ("Va" 0.2490793 52932.07 "VmidP" 0.9101286
           -131942.1
       ((2.127916e-11 8.28333e-15) 5.269614e-10 -106.7205)
   ("100.5u"
       ("Va" 0.2215643 56875.43 "VmidP" 0.9567804
           -64701.29
       ((2.236783e-11 8.3611e-15) 5.402731e-10 -106.5038)
   ("100u"
       ("Va" 0.1921638 60509.95 "VmidP" 0.9788811
           -29470.66
       ((2.737521e-11 8.598666e-15) 5.976956e-10 -105.6264)
   ("99.5u"
       ("Va" 0.1609975 63957.0 "VmidP" 0.9886011
           -12394.18
       ((3.995595e-11 8.204394e-15) 7.220911e-10 -103.9842)
   ("99u"
       ("Va" 0.1281264 67355.62 "VmidP" 0.9924951
           -4611.735
       ((1.303551e-10 7.801459e-15) 1.304263e-09 -98.84872)
   ("98.5u"
       ("Va" 0.09354027 70826.85 "VmidP" 0.9937917
           -1216.622
       ((1.284531e-09 7.009538e-15) 4.094243e-09 -88.91255)
   ("98u" "Error")
Where the last number (bolded) in each list is the phase noise in dBc/Hz.  the "error" entrys are where the PSS did not converge. "Va" is the slow chargeup, fast charge down node and "VmidP" is an internal comparator node. The two numbers following Va and VmidP are the voltage at t=0 and dV/dt at t=0. I specified "Va" as the oscillator node for the pss simulation. It seems like pss fails when tstab is chosen such that the pss guessing game starts close to the extremely fast falling edge of the oscillator,  and the phase noise result improves if we start later in the RC chargeup period. There is a nearly 30dB difference in these results for the same oscillator, even though PSS converged in each case. My question is, which result can I trust, becauase the results are so wildly varying?
Thanks in Advance
Xiao Wang
Re: Pnoise: RC relaxation oscillator simulation, results dependent on TStab
Reply #1 - Jul 26th, 2009, 12:36am
Interestingly when I turn off augumented pnoise:
Regular (non augumented Pnoise, turbo solver)
(("104.5u" "Error")
   ("104u"
       ("Va" 0.2584785 51591.15 "VmidP" 0.8837754
           -166661.5
       ((1.58022e-11 9.134028e-15) 4.516825e-10 -108.0128)
   ("103.5u" "Error")
   ("103u" "Error")
   ("102.5u"
       ("Va" 0.172236 62908.75 "VmidP" 0.9860699
           -16984.06
       ((1.721947e-11 8.37348e-15) 4.715021e-10 -107.6398)
   ("102u" "Error")
   ("101u"
       ("Va" 0.07004445 73383.45 "VmidP" 0.9939822
           -141.7666
       ((1.685612e-11 6.915519e-15) 4.665039e-10 -107.7324)
   ("100.5u"
       ("Va" 0.2955239 44910.93 "VmidP" 0.6764826
           -404095.6
       ((1.141454e-11 8.563347e-15) 3.838876e-10 -109.4254)
   ("100u" "Error")
   ("99.5u" "Error")
   ("99u"
       ("Va" 0.261198 51149.22 "VmidP" 0.8747783
           -178366.0
       ((1.559862e-11 9.128474e-15) 4.487559e-10 -108.0691)
   ("98.5u" "Error")
   ("98u"
       ("Va" 0.2123941 58195.96 "VmidP" 0.9657643
           -50861.31
       ((1.735005e-11 9.133293e-15) 4.732865e-10 -107.607)
The results are extremely consistent. Regular (non augumented) pnoise is also based on Demir's algorithm from what I understand. These are also fairly consistent with the good results from the augumented mode. however I do get this warning:
Warning from spectre during PNoise analysis `pnoise'.
   WARNING (SPCRTRF-15091): The shooting small signal analysis is unable to
       find an oscillator mode for the oscillator (the cuicuit does not     behave
       like an oscillator), To fix the problem,
       1) Tighten the simulation tolerance for the PSS analysis by either
       using a tighter `errpreset' value (for example,
       errpreset=conservative), or by using a smaller `reltol' value (for
       example, reltol=1e-5). Rerun the simulation.
and it suggests turning on augmented pnoise, lol.  This problem is a real head scratcher. Is there a chance these problems indicate a possible problem with the augmented pnoise for the shooting solver?
Xiao
