fmcarol
Hi All,
I want to simulate the "Output Jitter", is cycle-to-cycle jitter measured on the DLL output clock, excluding input clock jitter.
I use "PSS+Pnoise" simulate the circuit, but I confuse with some choices in Pnoise window.
1.Output Frequency Sweep Range(Hz) star ??Hz stop ??Hz
What shoule I fill?
2.Input Source:Voltage, Current, Port, None. Which shoule I select?
Thanks, carol
