May 11th, 2024, 6:47am
how to simulate the Digital Delay Lock Loop's jitter or phase noise (Read 2557 times)
fmcarol
Jul 29th, 2009, 1:21am
Hi All,
I want to simulate the "Output Jitter", is cycle-to-cycle jitter measured on the DLL output clock, excluding input clock jitter.
I use "PSS+Pnoise" simulate the circuit, but I confuse with some choices in Pnoise window.
1.Output Frequency Sweep Range(Hz)
star  ??Hz stop ??Hz
What shoule I fill?
2.Input Source:Voltage, Current, Port, None.
Which shoule I select?
carol
