Aug 16th, 2024, 4:03am
Can Spectre Solve the single-end output SC-integrator in PSS ? (Read 2612 times)
larry_suyung
Jul 29th, 2009, 6:22am
Hello, friends
I am trying to use Spectre to get the variance of the output noise of SC-integrator. The circuit is the same as Fig. 4, in Dr.Schreier's 2005 TCAS1 paper as attached.
The first confusing problem is that is if this is an ideal OTA, then even no input, the noise is summed in every cycle. Finally the integrated noise saturates the OTA.  This can be seen in Eq(39) of attached paper.
The sesond question is that even no input, the offset and switch injection keeps the output continually ramping out at every cycle by its integration property. Therefore there is no periodic solution. So How can Spectre get the PSS and PNOISE ? But the manual said Spectre can solve SC-circuits?
Thanks so much...Larry  (SuYung)
larry_suyung
Re: Can Spectre Solve the single-end output SC-integrator in PSS ?
Reply #1 - Aug 2nd, 2009, 3:07am
Dear Friends,
I derived the accumation effect of SC integrator, as attached.
The formula is confirmed with the results of W. Ki and G. C. Temes, “Offset-compensated switched-capacitor integrators,”
in Proc. IEEE Int. Symp. Circuits and Systems, May 1990, pp.
2829–2832.
My derived reults consider the offset and finite gain. This derivation is also done in Dr. Murmann's (Stanford) lecture note. But he did not include the finite gain of the OTA.
From this attached reults, it verified my last post that even no input, the single ended SC-integrator has no "periodic solution". The output goes up at every cycle.  This case is different than Dr. Kendurt's paper of  Simulating switched-capacitor filters with Spectre RF.
So I wonder how Spectre can handle  this single-ended SC-integrator ?
Thanks so much to friends.    Larry-SuYung
larry_suyung
Reply #2 - Aug 13th, 2009, 4:31am
Dear Friends,
I have to tune the input down to several digits to have PSS of a open loop SC integrator worked.
Maybe we should use close loop for SC integrator not open loop .  Thanks
