Jun 30th, 2025, 3:27pm
What is the best accuracy that a TCXO can achieve? (Read 19304 times)
Jul 30th, 2009, 7:57pm
I guess it depends heavily on the frequency stability over operating temperature range of crystals. But I don't know what's the extreme that the crystal industry can approach. Any literature, datasheet, website are appreciated.
Yawei
Kevin Aylward
Re: What is the best accuracy that a TCXO can achieve?
Reply #1 - Jul 14th, 2013, 1:13am
The best SOA for a TCXO is going to be around 0.05 ppm over -40 Deg to 85 Deg to 0.1ppm. Most achieve a bit worse, e.g. 0.5 ppm. XTALS un-compensated are around 20 ppm to 100 ppm. XTAL temperature hysteresis is a killer. OCXO (oven) gets you to the ppb level, in part, because the xtal is not allowed to move, much.
Kevin Aylward
